Ga door naar hoofdinhoud
Nokia 6 Midframe Replacement
Wat je nodig hebt
  1. Nokia 6 Midframe Replacement, Display Assembly: stap 1, afbeelding 1 van 3 Nokia 6 Midframe Replacement, Display Assembly: stap 1, afbeelding 2 van 3 Nokia 6 Midframe Replacement, Display Assembly: stap 1, afbeelding 3 van 3
    • Power off your Nokia 6 before beginning disassembly.
    • Insert the SIM card ejection tool into the hole on the left side of the phone.
    • Remove the SIM card and microSD card.
  2. Nokia 6 Midframe Replacement: stap 2, afbeelding 1 van 1
    • If your display glass is cracked, take precaution by taping over the display to prevent further breakage and harm.
    • Lay overlapping strips of clear packing tape over the Nokia 6's display until the whole screen is covered.
  3. Nokia 6 Midframe Replacement: stap 3, afbeelding 1 van 1
    • To soften the adhesive, use a heat gun and heat one edge of the phone for five minutes.
    • To use the heat gun, plug it into an outlet.
    • When the heat gun is plugged in, the heat gun automatically turns on and will start blowing hot air.
  4. Nokia 6 Midframe Replacement: stap 4, afbeelding 1 van 1
    • Take a Jimmy and slide it under the glass after the adhesive has been softened.
    • Place a pick under the glass after lifting with the pry tool so that the screen won't re-adhere to the frame again.
    • Make sure to not touch the LCD edge underneath the glass layer with the metal pry tool or the cards. This can damage the ribbon cables underneath and compromise the structural integrity of the phone itself.
    • The corners of the screen are the most fragile part of the screen. Make sure that the entire edge of the screen is dislodged from the frame before prying at the corners.
  5. Nokia 6 Midframe Replacement: stap 5, afbeelding 1 van 1
    • Lift the screen off of the phone.
  6. Nokia 6 Midframe Replacement: stap 6, afbeelding 1 van 2 Nokia 6 Midframe Replacement: stap 6, afbeelding 2 van 2
    • Use a Phillips #000 screwdriver to remove the 1 mm x 1.4 mm screw holding down the metal bracket over the screen ribbon connector.
  7. Nokia 6 Midframe Replacement: stap 7, afbeelding 1 van 1
    • Remove the metal bracket with a tweezer.
  8. Nokia 6 Midframe Replacement: stap 8, afbeelding 1 van 1
    • Use a spudger to disconnect the screen ribbon connector and free the display assembly.
    • The corners and edge of the LCD are fragile. Be careful attaching it to the back of the phone.
    • Carefully remove the screen from the device.
  9. Nokia 6 Midframe Replacement, Home Button Assembly: stap 9, afbeelding 1 van 1
    • Disconnect the battery connector with a spudger.
  10. Nokia 6 Midframe Replacement: stap 10, afbeelding 1 van 2 Nokia 6 Midframe Replacement: stap 10, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use a Phillips #00 screwdriver to remove the 1.2 mm x 2.2 mm screw in the upper hand corner of the phone.
    • Use tweezers to remove the bracket.
  11. Nokia 6 Midframe Replacement: stap 11, afbeelding 1 van 2 Nokia 6 Midframe Replacement: stap 11, afbeelding 2 van 2
    • Detach the cable with the black nylon spudger.
    • Detach the home button and remove it from the device.
  12. Nokia 6 Midframe Replacement, Midframe: stap 12, afbeelding 1 van 1
    • Remove 18 screws.
    • There is one 1 mm x 1.4 mm screw that needs to be removed by a Phillips #000 screwdriver.
    • One of the screws is 1.2 mm x 4.2 mm and will be removed by a Phillips #00.
    • The remaining 16 screws can be removed by the Phillips #00 screwdriver and are 1.2 mm x 2.2 mm.
  13. Nokia 6 Midframe Replacement: stap 13, afbeelding 1 van 2 Nokia 6 Midframe Replacement: stap 13, afbeelding 2 van 2
    • Decouple the midframe with the spudger and remove the midframe from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Chrissy Robins
1.585 Reputatie
10 handleidingen geschreven
Cal Poly, Team S9-G15, Maness Spring 2019 Lid van Cal Poly, Team S9-G15, Maness Spring 2019
CPSU-MANESS-S19S9G15
4 Leden
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 21
Altijd: 785
