Ga door naar hoofdinhoud
Nokia 5310b XpressMusic LCD Screen Replacement
Wat je nodig hebt
  1. Nokia 5310b XpressMusic LCD Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Slide the black battery cover down and off the phone with your thumb to remove it.
    • The battery cover is not shown in this picture
  2. Nokia 5310b XpressMusic LCD Screen Replacement: stap 2, afbeelding 1 van 2 Nokia 5310b XpressMusic LCD Screen Replacement: stap 2, afbeelding 2 van 2
    • Gently lift the battery with a fingernail to remove it from the back of the phone.
    • Keep the battery removed for the next steps
    • The battery may be replaced or repaired at this step.
  3. Nokia 5310b XpressMusic LCD Screen Replacement, Keypad: stap 3, afbeelding 1 van 3 Nokia 5310b XpressMusic LCD Screen Replacement, Keypad: stap 3, afbeelding 2 van 3 Nokia 5310b XpressMusic LCD Screen Replacement, Keypad: stap 3, afbeelding 3 van 3
    • On some models, the front case is screwed down from the back. Follow steps 5 and 6 first to remove the camera cover and two T6 screws, BEFORE removing the faceplate.
    • Find a small latch under the music keys and in the middle of each side of the faceplate.
    • Gently lift the edges of the front faceplate off the phone using a spudger.
  4. Nokia 5310b XpressMusic LCD Screen Replacement: stap 4, afbeelding 1 van 2 Nokia 5310b XpressMusic LCD Screen Replacement: stap 4, afbeelding 2 van 2
    • Flip the phone over to the front side.
    • Lift up the keypad from the bottom with either a spudger or your finger.
    • At this time the keypad can be removed and replaced.
  5. Nokia 5310b XpressMusic LCD Screen Replacement, Motherboard: stap 5, afbeelding 1 van 1
    • Flip the phone over to the back side.
    • Unsnap the back camera cover from the phone.
    • Lift to remove the back camera cover from the phone after it has been unsnapped.
  6. Nokia 5310b XpressMusic LCD Screen Replacement: stap 6, afbeelding 1 van 2 Nokia 5310b XpressMusic LCD Screen Replacement: stap 6, afbeelding 2 van 2
    • Unscrew and remove the two screws on either side of the camera with the T6 Torx Screwdriver head.
    • Unscrew and remove the 4 screws located at each corner of the white keypad base using the T6 Torx Screwdriver head.
  7. Nokia 5310b XpressMusic LCD Screen Replacement: stap 7, afbeelding 1 van 1
    • Unclip the faceplate plug (ribbon) located in the lower left corner of the motherboard.
  8. Nokia 5310b XpressMusic LCD Screen Replacement: stap 8, afbeelding 1 van 2 Nokia 5310b XpressMusic LCD Screen Replacement: stap 8, afbeelding 2 van 2
    • Find the 2 metal clips located in the middle of the left and right sides of the motherboard.
    • Pry the 2 metal clips open up by using a spudger.
    • At this point the phone should come apart into 2 pieces (the motherboard/LCD screen and the faceplate).
  9. Nokia 5310b XpressMusic LCD Screen Replacement, LCD Screen: stap 9, afbeelding 1 van 1
    • Unclip the ribbon plug located on the top of the LCD screen that connects it to the motherboard.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Max Kirby
518 Reputatie
4 handleidingen geschreven
Cal Poly, Team 15-14, Regan Spring 2011 Lid van Cal Poly, Team 15-14, Regan Spring 2011
CPSU-REGAN-S11S15G14
3 Leden
8 handleidingen geschreven
1Gids Commentaar
Thank you much! As efficient & thorough as it gets!
REDACTED FREE PRESS - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 21
Altijd: 9,426
