Inleiding
Use this guide to replace the front cover and the keypad of your Nokia 515
Wat je nodig hebt
Remove the back cover with your fingers or with the eject tool which is included by Nokia.
To remove the keypad, you should use the spudger to push the top clamps down a little bit while pressing your fingers against the inside of the keypad.
The keypad should be loose at the top.
To remove the bottom, just use a little bit of force to pull it off the front panel.
You did it!
You did it!
3 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Leon helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
