Ga door naar hoofdinhoud
Nokia 3360 Charger Connector Replacement
Wat je nodig hebt
  1. Nokia 3360 Charger Connector Replacement, Battery: stap 1, afbeelding 1 van 1
    • Press down on the back of the phone with your thumb. Then slide the back plate upward toward the top of the phone.
    • Lift the back plate off the phone.
  2. Nokia 3360 Charger Connector Replacement: stap 2, afbeelding 1 van 2 Nokia 3360 Charger Connector Replacement: stap 2, afbeelding 2 van 2
    • To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time.
  3. Nokia 3360 Charger Connector Replacement: stap 3, afbeelding 1 van 2 Nokia 3360 Charger Connector Replacement: stap 3, afbeelding 2 van 2
    • Lift the battery out of the phone.
    • Note: Upon reassembly of the phone refer to second picture. The bottom of the battery with three square openings should line up with the prongs sticking out of the phone.
  4. Nokia 3360 Charger Connector Replacement, Charger Connector: stap 4, afbeelding 1 van 2 Nokia 3360 Charger Connector Replacement, Charger Connector: stap 4, afbeelding 2 van 2
    • Use a pry tool towards the bottom of the phone to gently detach the face plate from the dark grey phone frame.
    • Hold phone frame down while separating the face plate.
    • Separate the faceplate and grey phone frame.
  5. Nokia 3360 Charger Connector Replacement: stap 5, afbeelding 1 van 2 Nokia 3360 Charger Connector Replacement: stap 5, afbeelding 2 van 2
    • Remove the six screws using a T6 screwdriver. (refer to second picture to help identify T6 screwdriver head).
    • NOTE: When reassembling the device be sure to not over tighten the screws.
  6. Nokia 3360 Charger Connector Replacement: stap 6, afbeelding 1 van 2 Nokia 3360 Charger Connector Replacement: stap 6, afbeelding 2 van 2
    • Place the phone with the screen facing down onto a flat surface.
    • Place the flat edge of the pry tool into the seam on the side, just above the screen. (refer to picture on where to place pry tool).
    • Push the pry tool into the seam.
    • Pry apart the plates until the cover separates from the rest of the phone. Be careful not to apply too much pressure
    • Proceed to pull the front cover away from the rest of the phone. (refer to second picture for results) The marking foreshadows what we will be using in the next step.
  7. Nokia 3360 Charger Connector Replacement: stap 7, afbeelding 1 van 3 Nokia 3360 Charger Connector Replacement: stap 7, afbeelding 2 van 3 Nokia 3360 Charger Connector Replacement: stap 7, afbeelding 3 van 3
    • Locate the charger connector. (refer to picture with marker)
    • Carefully lift the charger connector upward to detach.
    • NOTE: When reassembling this device the charger connector is placed toward the bottom of the phone. The connector has a peg sticking out that fits into the logic board. (refer to third picture)
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jonathan Phung
15 Reputatie
1 Handleiding geschreven
Cal Poly, Team 8-39, Regan Winter 2010 Lid van Cal Poly, Team 8-39, Regan Winter 2010
CPSU-REGAN-W10S8G39
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 5,218
