Ga door naar hoofdinhoud
Nokia 3310 3G Speaker Replacement
Wat je nodig hebt
  1. Nokia 3310 3G Speaker Replacement, Battery: stap 1, afbeelding 1 van 2 Nokia 3310 3G Speaker Replacement, Battery: stap 1, afbeelding 2 van 2
    • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
  2. Nokia 3310 3G Speaker Replacement: stap 2, afbeelding 1 van 2 Nokia 3310 3G Speaker Replacement: stap 2, afbeelding 2 van 2
    • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • This specific device did not come with a battery.
  3. Nokia 3310 3G Speaker Replacement, Frame: stap 3, afbeelding 1 van 3 Nokia 3310 3G Speaker Replacement, Frame: stap 3, afbeelding 2 van 3 Nokia 3310 3G Speaker Replacement, Frame: stap 3, afbeelding 3 van 3
    • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
    • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
  4. Nokia 3310 3G Speaker Replacement, Motherboard: stap 4, afbeelding 1 van 3 Nokia 3310 3G Speaker Replacement, Motherboard: stap 4, afbeelding 2 van 3 Nokia 3310 3G Speaker Replacement, Motherboard: stap 4, afbeelding 3 van 3
    • Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
  5. Nokia 3310 3G Speaker Replacement, Speaker: stap 5, afbeelding 1 van 2 Nokia 3310 3G Speaker Replacement, Speaker: stap 5, afbeelding 2 van 2
    • Using a metal spudger, lodge the tip underneath the speaker and between the soft foam surrounding the screen.
    • Use the metal spudger to leverage out the speaker.
    • The speaker is attached to the shell with an adhesive. Do not be too aggressive in your removal, else the speaker will come apart.
Conclusie
Aaron LeBlanc
723 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S3-G3, Peak Fall 2018 Lid van UMass Dartmouth, Team S3-G3, Peak Fall 2018
UMASSD-PEAK-F18S3G3
3 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 1,435
