Inleiding
If you have cracked or damaged your screen, this guide will provide you with a step by step instructions on how to take the device apart to access it.
Wat je nodig hebt
Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
With the motherboard removed, the only thing holding the screen into place is the snap plug on the back of the motherboard.
Using a spudger, leverage the top snap up to disconnect it (photo shows motherboard rotated 90 degrees counterclockwise).
4 andere personen hebben deze handleiding voltooid.
