Ga door naar hoofdinhoud
Nokia 3310 3G Outer Frame Replacement
Wat je nodig hebt
  1. Nokia 3310 3G Outer Frame Replacement, Battery: stap 1, afbeelding 1 van 2 Nokia 3310 3G Outer Frame Replacement, Battery: stap 1, afbeelding 2 van 2
    • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
  2. Nokia 3310 3G Outer Frame Replacement: stap 2, afbeelding 1 van 2 Nokia 3310 3G Outer Frame Replacement: stap 2, afbeelding 2 van 2
    • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • This specific device did not come with a battery.
  3. Nokia 3310 3G Outer Frame Replacement, Frame: stap 3, afbeelding 1 van 3 Nokia 3310 3G Outer Frame Replacement, Frame: stap 3, afbeelding 2 van 3 Nokia 3310 3G Outer Frame Replacement, Frame: stap 3, afbeelding 3 van 3
    • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
    • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
  4. Nokia 3310 3G Outer Frame Replacement, Motherboard: stap 4, afbeelding 1 van 3 Nokia 3310 3G Outer Frame Replacement, Motherboard: stap 4, afbeelding 2 van 3 Nokia 3310 3G Outer Frame Replacement, Motherboard: stap 4, afbeelding 3 van 3
    • Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
  5. Nokia 3310 3G Outer Frame Replacement, Speaker: stap 5, afbeelding 1 van 2 Nokia 3310 3G Outer Frame Replacement, Speaker: stap 5, afbeelding 2 van 2
    • Using a metal spudger, lodge the tip underneath the speaker and between the soft foam surrounding the screen.
    • Use the metal spudger to leverage out the speaker.
    • The speaker is attached to the shell with an adhesive. Do not be too aggressive in your removal, else the speaker will come apart.
  6. Nokia 3310 3G Outer Frame Replacement, Outer Frame: stap 6, afbeelding 1 van 1
    • Using your finger, push the keyboard insert out of the front outer frame.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Aaron LeBlanc
723 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S3-G3, Peak Fall 2018 Lid van UMass Dartmouth, Team S3-G3, Peak Fall 2018
UMASSD-PEAK-F18S3G3
3 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 12
Altijd: 940
