Inleiding
If the frame of your Nokia 3310 3G is cracked or damaged, this guide will help you replace it.
Wat je nodig hebt
Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
Using a metal spudger, lodge the tip underneath the speaker and between the soft foam surrounding the screen.
Use the metal spudger to leverage out the speaker.
Using your finger, push the keyboard insert out of the front outer frame.
7 andere personen hebben deze handleiding voltooid.
