Ga door naar hoofdinhoud
Nokia 3300B Motherboard Replacement
Wat je nodig hebt
  1. Nokia 3300B Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 Nokia 3300B Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the Nokia 3300B over with the back-side facing towards you.
    • Gently press the button on the back of the battery cover to release the cover and slide up.
  2. Nokia 3300B Motherboard Replacement: stap 2, afbeelding 1 van 2 Nokia 3300B Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Lift the battery out of the back of the phone.
    • It is easiest to lift the battery out of the phone from the right-hand side, as seen in the picture.
  3. Nokia 3300B Motherboard Replacement, Keyboard: stap 3, afbeelding 1 van 2 Nokia 3300B Motherboard Replacement, Keyboard: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Gently push the blue tabs on the top of the phone out of their slots.
    • With the phone facing up, pop the blue faceplate off by using your fingernail (or some tweezers) and working your way around the phone.
    • Note: If the blue cover does not detach easily use your finger nails to try and split it open, as seen in the picture.
  4. Nokia 3300B Motherboard Replacement: stap 4, afbeelding 1 van 1
    • With the screen still facing you, lift and remove the blue faceplate.
  5. Nokia 3300B Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Grab the sides of the keypad and lift each side up vertically, until the keypad is completely removed.
    • If you encounter resistance while removing the keypad, be sure to lift up evenly on both sides to ensure that the pins do not snap.
    • When replacing the keypad, make sure that the plastic pegs all enter their proper holes.
  6. Nokia 3300B Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 2 Nokia 3300B Motherboard Replacement, Motherboard: stap 6, afbeelding 2 van 2
    • Remove the six Torx T6 screws from the phone's front case.
  7. Nokia 3300B Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Pull up on the front case containing the screen to separate it from the rest of the phone.
    • Gently lift the main board out of the back case.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Jose Quezada
50 Reputatie
1 Handleiding geschreven
Cal Poly, Team 18-65, Johann Spring 2010 Lid van Cal Poly, Team 18-65, Johann Spring 2010
CPSU-JOHANN-S10S18G65
4 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 2,912
