Inleiding
The LCD is difficult to get to and the guide requires a moderate amount of work. Tiny parts require patience during disassembly.
Wat je nodig hebt
Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
Using your fingernails or another tool, pry the front face plate out along its edges and corners.
Once the cover plate has been removed, the keypad should easily pop out.
