Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Press the button on the back of the phone and slide the back panel off.
Remove the battery by pulling it from the phone.
Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
Separate the front cover from the main body of the phone.
Remove the six screws along the edges of the phone.
Pull the screen assembly from the base of the phone.
Carefully lift the keypad portion of the screen assembly from the circuit board.
Separate the screen from the circuit board.
Reconnect the ports during reassembly or the screen will not function properly.
Gently push down on the screen to pop it off of the assembly.
When the screen falls out the assembly, two white tabs will fall out with it.
Één andere persoon heeft deze handleiding voltooid.
