Ga door naar hoofdinhoud
Nokia 2630b Screen / Front Case Replacement
Wat je nodig hebt
  1. Nokia 2630b Screen / Front Case Replacement, Battery Case: stap 1, afbeelding 1 van 2 Nokia 2630b Screen / Front Case Replacement, Battery Case: stap 1, afbeelding 2 van 2
    • Press each release button on either side of the battery cover and simultaneously remove the battery cover from the phone.
  2. Nokia 2630b Screen / Front Case Replacement: stap 2, afbeelding 1 van 1
    • Pull the battery out of the phone with your fingers.
  3. Nokia 2630b Screen / Front Case Replacement, Screen / Front Case: stap 3, afbeelding 1 van 1
    • Remove the two screws on either side of the battery case using the microscrewdriver using the T5 bit
    • The T5 bit has a star shaped end and has "T5" engraved on the side of the bit for easy identification
    • NOTE: Keep the screws in a safe place while you continue working.
  4. Nokia 2630b Screen / Front Case Replacement: stap 4, afbeelding 1 van 3 Nokia 2630b Screen / Front Case Replacement: stap 4, afbeelding 2 van 3 Nokia 2630b Screen / Front Case Replacement: stap 4, afbeelding 3 van 3
    • Separate the front case from the back case using the iPod opener
    • NOTE: The keypad is a loose piece and may fall out
  5. Nokia 2630b Screen / Front Case Replacement: stap 5, afbeelding 1 van 1
    • Remove screws using the same T5 screw bit to release the computer chip from the case
  6. Nokia 2630b Screen / Front Case Replacement: stap 6, afbeelding 1 van 1
    • Carefully lift the black frame off the screen with your fingers
  7. Nokia 2630b Screen / Front Case Replacement: stap 7, afbeelding 1 van 1
    • Carefully remove the computer chip and screen out of the black case with your fingers
  8. Nokia 2630b Screen / Front Case Replacement: stap 8, afbeelding 1 van 2 Nokia 2630b Screen / Front Case Replacement: stap 8, afbeelding 2 van 2
    • The screen is attached to the motherboard by an orange ribbon
    • Carefully detach the ribbon from the motherboard using your fingers
  9. Nokia 2630b Screen / Front Case Replacement: stap 9, afbeelding 1 van 1
    • Reattach new screen by connecting the orange ribbon to the computer chip
  10. Nokia 2630b Screen / Front Case Replacement: stap 10, afbeelding 1 van 2 Nokia 2630b Screen / Front Case Replacement: stap 10, afbeelding 2 van 2
    • Place computer chip and screen back into black case
  11. Nokia 2630b Screen / Front Case Replacement: stap 11, afbeelding 1 van 1
    • Place black frame back over screen
  12. Nokia 2630b Screen / Front Case Replacement: stap 12, afbeelding 1 van 2 Nokia 2630b Screen / Front Case Replacement: stap 12, afbeelding 2 van 2
    • Carefully place keypad back in place
  13. Nokia 2630b Screen / Front Case Replacement: stap 13, afbeelding 1 van 2 Nokia 2630b Screen / Front Case Replacement: stap 13, afbeelding 2 van 2
    • Snap the front case back in place with the bottom case with your fingers
  14. Nokia 2630b Screen / Front Case Replacement: stap 14, afbeelding 1 van 1
    • Reassemble screws with microscrewdriver
  15. Nokia 2630b Screen / Front Case Replacement: stap 15, afbeelding 1 van 1
    • Slide battery back into place
  16. Nokia 2630b Screen / Front Case Replacement: stap 16, afbeelding 1 van 1
    • Snap battery cover back into place
Conclusie
To reassemble your device, follow these instructions in reverse order. Make sure to snap the new screen / front case securely into place.
Eric
51 Reputatie
4 handleidingen geschreven
Cal Poly, Team 9-61, Walters Spring 2011 Lid van Cal Poly, Team 9-61, Walters Spring 2011
CPSU-WALTERS-S11S9G61
5 Leden
5 handleidingen geschreven
2 opmerkingen
Great guide :-) I have a Nokia 2630 too and people can no longer hear me on calls, even though I can hear them. Do you know what could be wrong? Do you think this is something I could fix myself? Thanks!
jfg - Antwoord
You could try getting a neodymium magnet and run it across the earpiece grill. In my father's case, a lot of metal powder was in there, pressing in the speaker membrane; the alternative is cleaning it (which does require opening the phone using Eric's very nice guide). The alternative to those is ordering an earpiece online - but usually those are really bad quality, so trying to fix the original one would be advisable
Darie H -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 3,796
