Ga door naar hoofdinhoud
Nokia 2610 Front Pannel Replacement
Wat je nodig hebt
  1. Nokia 2610 Front Pannel Replacement, Battery and Sim Card: stap 1, afbeelding 1 van 3 Nokia 2610 Front Pannel Replacement, Battery and Sim Card: stap 1, afbeelding 2 van 3 Nokia 2610 Front Pannel Replacement, Battery and Sim Card: stap 1, afbeelding 3 van 3
    • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
  2. Nokia 2610 Front Pannel Replacement: stap 2, afbeelding 1 van 3 Nokia 2610 Front Pannel Replacement: stap 2, afbeelding 2 van 3 Nokia 2610 Front Pannel Replacement: stap 2, afbeelding 3 van 3
    • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
  3. Nokia 2610 Front Pannel Replacement: stap 3, afbeelding 1 van 3 Nokia 2610 Front Pannel Replacement: stap 3, afbeelding 2 van 3 Nokia 2610 Front Pannel Replacement: stap 3, afbeelding 3 van 3
    • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
    • After removal, lower the metal sim card holder into its original position.
  4. Nokia 2610 Front Pannel Replacement, Front Pannel: stap 4, afbeelding 1 van 2 Nokia 2610 Front Pannel Replacement, Front Pannel: stap 4, afbeelding 2 van 2
    • Insert the plastic opening tool into the crack between the front and back panels.
    • Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
  5. Nokia 2610 Front Pannel Replacement: stap 5, afbeelding 1 van 2 Nokia 2610 Front Pannel Replacement: stap 5, afbeelding 2 van 2
    • Lift the bottom of the front cover away from the phone.
    • Continue lifting until the top of the front cover is fully removed from the phone.
    • Note: To replace the Keypad, gently lift it out of the front cover. It is located below the clear viewing window.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Andrew Wood
336 Reputatie
3 handleidingen geschreven
Cal Poly, Team 7-52, Amido Fall 2010 Lid van Cal Poly, Team 7-52, Amido Fall 2010
CPSU-AMIDO-F10S7G52
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 2,137
