Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Red arrows indicate which screws must be removed in order to get to the motherboard.
Wedge a flat head in between the back and phone exterior starting at the bottom corners.
As you move toward the top, remove the camera and volume buttons.
Remove the back, being careful not to detach the motherboard from the back and to not pull them fully out (both attached at the upper left corner by a black strip).
