Inleiding
When the cell phone speaker is blown and it needs to be replaced, this guide will show you how.
Wat je nodig hebt
Be sure cell phone is off before you begin to disassemble the phone.
Press the button on the bottom of the back of the cell phone.
Slide rear panel down and remove it.
Insert the plastic opening tool under the faceplate.
Separate the faceplate from main body by twisting the prying tool with some force.
The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
Locate and remove the six screws on the front of the phone using a T6 Torx.
All 6 screws are 6.9mm long.
With the LCD unit removed, gently press out the speaker with a non-metallic pointed object.
