Onderdelen
Geen onderdelen nodig.
Insert the plastic opening tool under the faceplate.
  • Insert the plastic opening tool under the faceplate.
  • Separate the faceplate from main body by twisting the prying tool with some force.
  • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
Voeg opmerking toe
With the faceplate removed, simply peel off rubber key pad and remove.
  • With the faceplate removed, simply peel off rubber key pad and remove.
Voeg opmerking toe
  • Locate and remove the six screws on the front of the phone using a T6 Torx.
    • All 6 screws are 6.9mm long.
Voeg opmerking toe
  • After removing screws, lift the motherboard assembly straight off the cell phone body.
Voeg opmerking toe
  • Be sure cell phone is off before you begin to disassemble the phone.
  • Press the button on the bottom of the back of the cell phone.
  • Slide rear panel down and remove it.
Voeg opmerking toe
  • Using your fingernail, pry the back of the battery upwards and pull out.
Voeg opmerking toe
  • With the LCD unit removed, gently press out the speaker with a non-metallic pointed object.
Voeg opmerking toe
Conclusie
Andres Echeverria
4 Reputatie
3 handleidingen geschreven
Cal Poly, Team 20-8, Maness Fall 2010 Lid van Cal Poly, Team 20-8, Maness Fall 2010
CPSU-MANESS-F10S20G8
4 Leden
28 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 217
