Ga door naar hoofdinhoud
Nokia 2128i Charging Port Replacement
Wat je nodig hebt
  1. Nokia 2128i Charging Port Replacement, Battery: stap 1, afbeelding 1 van 3 Nokia 2128i Charging Port Replacement, Battery: stap 1, afbeelding 2 van 3 Nokia 2128i Charging Port Replacement, Battery: stap 1, afbeelding 3 van 3
    • Be sure cell phone is off before you begin to disassemble the phone.
    • Press the button on the bottom of the back of the cell phone.
    • Slide rear panel down and remove it.
  2. Nokia 2128i Charging Port Replacement: stap 2, afbeelding 1 van 3 Nokia 2128i Charging Port Replacement: stap 2, afbeelding 2 van 3 Nokia 2128i Charging Port Replacement: stap 2, afbeelding 3 van 3
    • Using your fingernail, pry the back of the battery upwards and pull out.
  3. Nokia 2128i Charging Port Replacement, Faceplate: stap 3, afbeelding 1 van 3 Nokia 2128i Charging Port Replacement, Faceplate: stap 3, afbeelding 2 van 3 Nokia 2128i Charging Port Replacement, Faceplate: stap 3, afbeelding 3 van 3
    • Insert the plastic opening tool under the faceplate.
    • Separate the faceplate from main body by twisting the prying tool with some force.
    • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
  4. Nokia 2128i Charging Port Replacement, Keypad: stap 4, afbeelding 1 van 3 Nokia 2128i Charging Port Replacement, Keypad: stap 4, afbeelding 2 van 3 Nokia 2128i Charging Port Replacement, Keypad: stap 4, afbeelding 3 van 3
    • With the faceplate removed, simply peel off rubber key pad and remove.
  5. Nokia 2128i Charging Port Replacement, Motherboard Assembly: stap 5, afbeelding 1 van 3 Nokia 2128i Charging Port Replacement, Motherboard Assembly: stap 5, afbeelding 2 van 3 Nokia 2128i Charging Port Replacement, Motherboard Assembly: stap 5, afbeelding 3 van 3
    • Locate and remove the six screws on the front of the phone using a T6 Torx.
    • All 6 screws are 6.9mm long.
  6. Nokia 2128i Charging Port Replacement: stap 6, afbeelding 1 van 3 Nokia 2128i Charging Port Replacement: stap 6, afbeelding 2 van 3 Nokia 2128i Charging Port Replacement: stap 6, afbeelding 3 van 3
    • After removing screws, lift the motherboard assembly straight off the cell phone body.
  7. Nokia 2128i Charging Port Replacement, Charging Port: stap 7, afbeelding 1 van 2 Nokia 2128i Charging Port Replacement, Charging Port: stap 7, afbeelding 2 van 2
    • With the logic board and LCD unit removed, gently pry out the charging port.
Conclusie
Curtis Lutje
28 Reputatie
6 handleidingen geschreven
Cal Poly, Team 20-8, Maness Fall 2010 Lid van Cal Poly, Team 20-8, Maness Fall 2010
CPSU-MANESS-F10S20G8
4 Leden
24 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 2,933
