Ga door naar hoofdinhoud
Nokia 1100b RH-36 Motherboard and Keyboard Replacement
Wat je nodig hebt
  1. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery Cover: stap 1, afbeelding 1 van 2 Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery Cover: stap 1, afbeelding 2 van 2
    • Flip the phone over so that the screen faces down.
    • Press the gray button on the battery cover and slide it down off the back of the phone.
  2. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery: stap 2, afbeelding 1 van 1
    • Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
    • Gently pry the battery out of the phone.
  3. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Inner Casing: stap 3, afbeelding 1 van 2 Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Inner Casing: stap 3, afbeelding 2 van 2
    • Remove the six 6mm T6 Torx screws around the edge of the front of the phone.
    • Remove the metal frame holding the screen and speaker.
    You please Nokia 1100 Motherboard and keyboard Rely
    ajay gupta - Antwoord
  4. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Motherboard and Keyboard: stap 4, afbeelding 1 van 2 Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Motherboard and Keyboard: stap 4, afbeelding 2 van 2
    • Gently lift motherboard unit out of the case.
    • The motherboard and keyboard are one unit and are replaced together.
Conclusie
12 andere personen hebben deze handleiding voltooid.
James Szelenyi
262 Reputatie
1 Handleiding geschreven
Cal Poly, Team 10-43, Amido Spring 2013 Lid van Cal Poly, Team 10-43, Amido Spring 2013
CPSU-AMIDO-S13S10G43
4 Leden
14 handleidingen geschreven
Één opmerking
you nokia 1100 mother board please soon date…?
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 4,219
