Ga door naar hoofdinhoud
Inleiding
If the suction cup no longer sticks to surfaces or if the plastic has split, you will need to replace the suction cup with a new one.
Gereedschap
Onderdelen
  1. Nokero N400 Suction Cup Replacement, Remove Battery Cover: stap 1, afbeelding 1 van 3 Nokero N400 Suction Cup Replacement, Remove Battery Cover: stap 1, afbeelding 2 van 3 Nokero N400 Suction Cup Replacement, Remove Battery Cover: stap 1, afbeelding 3 van 3
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 Suction Cup Replacement, Unscrew Back Cover: stap 2, afbeelding 1 van 2 Nokero N400 Suction Cup Replacement, Unscrew Back Cover: stap 2, afbeelding 2 van 2
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 Suction Cup Replacement, Pry Open Back Cover: stap 3, afbeelding 1 van 2 Nokero N400 Suction Cup Replacement, Pry Open Back Cover: stap 3, afbeelding 2 van 2
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
  4. Nokero N400 Suction Cup Replacement, Begin Removal: stap 4, afbeelding 1 van 2 Nokero N400 Suction Cup Replacement, Begin Removal: stap 4, afbeelding 2 van 2
    • Using tweezers, push the edges of the back end of the suction cup inward.
  5. Nokero N400 Suction Cup Replacement, Remove Suction Cup: stap 5, afbeelding 1 van 2 Nokero N400 Suction Cup Replacement, Remove Suction Cup: stap 5, afbeelding 2 van 2
    • Flip the cover over and remove the suction cup by pulling at an angle.
    • Be careful not to tear the plastic housing.
    • During reassembly, make sure to press down uniformly on the suction cup for an even fit.
Conclusie
Daniel Bumiller
201 Reputatie
2 handleidingen geschreven
USF Tampa, Team 19-2, Blackwell Winter 2015 Lid van USF Tampa, Team 19-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G2
4 Leden
5 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 82
