Ga door naar hoofdinhoud
Nokero N400 LED Panel Replacement
Wat je nodig hebt
  1. Nokero N400 LED Panel Replacement, Remove Battery Cover: stap 1, afbeelding 1 van 3 Nokero N400 LED Panel Replacement, Remove Battery Cover: stap 1, afbeelding 2 van 3 Nokero N400 LED Panel Replacement, Remove Battery Cover: stap 1, afbeelding 3 van 3
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 LED Panel Replacement, Unscrew Back Cover: stap 2, afbeelding 1 van 2 Nokero N400 LED Panel Replacement, Unscrew Back Cover: stap 2, afbeelding 2 van 2
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 LED Panel Replacement, Pry Open Back Cover: stap 3, afbeelding 1 van 2 Nokero N400 LED Panel Replacement, Pry Open Back Cover: stap 3, afbeelding 2 van 2
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
  4. Nokero N400 LED Panel Replacement, Removing the LED Panel: stap 4, afbeelding 1 van 2 Nokero N400 LED Panel Replacement, Removing the LED Panel: stap 4, afbeelding 2 van 2
    • With the back cover of the device removed, lightly pull up on the LED assembly to lift it out of its housing.
    • The LED assembly will separate into three components; the light board, outer housing, and plastic lens.
  5. Nokero N400 LED Panel Replacement: stap 5, afbeelding 1 van 1
    • Set the outer housing and plastic lens aside.
    • Take a pair of pliers and cut the red and black wires connected to the light board.
    • Make sure to cut just below the light board.
    • To install the new light board, you will need to splice or solder the wires to the new light board.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kyle Burwell
173 Reputatie
1 Handleiding geschreven
USF Tampa, Team 19-2, Blackwell Winter 2015 Lid van USF Tampa, Team 19-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G2
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 349
