Ga door naar hoofdinhoud
Inleiding
Follow this guide to replace or change the colored lens inside of your Nokero N222-Huron in order to adapt the solar light to various situations.
  1. Nokero N222-Huron Colored Lens Replacement, Clear Cover: stap 1, afbeelding 1 van 1
    • Grasp the clear cover and the white housing and twist the cover counter-clockwise.
    • The lid may hold fast, but it will come off with some firm twisting.
  2. Nokero N222-Huron Colored Lens Replacement: stap 2, afbeelding 1 van 1
    • Lift the lid from the device
    • It may be helpful to use a spudger to pry under the lid if there is difficulty in getting a good grip on the smooth plastic.
  3. Nokero N222-Huron Colored Lens Replacement, Colored Lens: stap 3, afbeelding 1 van 3 Nokero N222-Huron Colored Lens Replacement, Colored Lens: stap 3, afbeelding 2 van 3 Nokero N222-Huron Colored Lens Replacement, Colored Lens: stap 3, afbeelding 3 van 3
    • Turn the lens until the slots line up with the retaining clips on the device.
    • Lift the lens off of the device. It should come off easily.
  4. Nokero N222-Huron Colored Lens Replacement: stap 4, afbeelding 1 van 2 Nokero N222-Huron Colored Lens Replacement: stap 4, afbeelding 2 van 2
    • When reinstalling the lends, line up the slots of the new lens with the retaining clips, and rotate the lens counter-clockwise.
    • You will hear an audible click when the lens is locked in place.
Conclusie
To reassemble your device, follow the instructions for the first two steps in reverse order.
Vinny Capone
549 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2013 Lid van UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S2G4
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 205
