Ga door naar hoofdinhoud
Nobis NB09 Battery Replacement
Wat je nodig hebt
  1. Nobis NB09 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before beginning this process, make sure the device is powered off.
    • Remove the screws holding the case together.
  2. Nobis NB09 Battery Replacement: stap 2, afbeelding 1 van 3 Nobis NB09 Battery Replacement: stap 2, afbeelding 2 van 3 Nobis NB09 Battery Replacement: stap 2, afbeelding 3 van 3
    • Use an opening tool to loosen and pry off the pink back plate.
  3. Nobis NB09 Battery Replacement: stap 3, afbeelding 1 van 2 Nobis NB09 Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the black electronic tape covering the circuit board.
  4. Nobis NB09 Battery Replacement: stap 4, afbeelding 1 van 1
    • Use the soldering iron to remove the black and red wires from the circuit board.
    • The black wire is the ground and the red wire is the battery positive terminal.
    • To reassemble, use the soldering iron to solder the leads at the end of the black (-) and red (+) wires from the new battery onto the proper terminals on the circuit board.
  5. Nobis NB09 Battery Replacement: stap 5, afbeelding 1 van 2 Nobis NB09 Battery Replacement: stap 5, afbeelding 2 van 2
    • Gently loosen the adhesive under the battery to avoid damaging it.
    • Use caution; the battery is soft and will bend very easily.
    • Dispose of the old battery properly at an electronic waste center or verified battery recycling store.
    • When reassembling, apply adhesive to the back of the new battery.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Jackson McAdams
390 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 7-1, Cichon Spring 2015 Lid van UMass Dartmouth, Team 7-1, Cichon Spring 2015
UMASSD-CICHON-S15S7G1
4 Leden
12 handleidingen geschreven
Één opmerking
where can i buy a battery from
Frederick Shipman - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 2,973
