Ga door naar hoofdinhoud
Nishiki Aero II Tire Removal
Wat je nodig hebt
  1. Nishiki Aero II Tire Removal, Removing Road Bike Front Wheel: stap 1, afbeelding 1 van 1
    • Turn the bike upside down.
  2. Nishiki Aero II Tire Removal: stap 2, afbeelding 1 van 1
    • Use a wrench to loosen the nut holding the wheel's axle on one side.
    • Once it's loose enough, continue removing the nut with your hand.
  3. Nishiki Aero II Tire Removal: stap 3, afbeelding 1 van 2 Nishiki Aero II Tire Removal: stap 3, afbeelding 2 van 2
    • After removing the nut, also remove the washer under it.
    • Keep note of how the washer has a small appendage that locks into a slot in the fork.
  4. Nishiki Aero II Tire Removal: stap 4, afbeelding 1 van 1
    • Follow the previous steps for the opposite side.
  5. Nishiki Aero II Tire Removal: stap 5, afbeelding 1 van 1
    • Lift the wheel up from the fork.
  6. Nishiki Aero II Tire Removal, Nishiki Aero II Tire Removal: stap 6, afbeelding 1 van 2 Nishiki Aero II Tire Removal, Nishiki Aero II Tire Removal: stap 6, afbeelding 2 van 2
    • Unscrew the cap from the air valve.
    • Release the tire's air by pressing a thin object on the center pin of the valve.
    • A hex wrench or any blunt object can be used.
  7. Nishiki Aero II Tire Removal: stap 7, afbeelding 1 van 3 Nishiki Aero II Tire Removal: stap 7, afbeelding 2 van 3 Nishiki Aero II Tire Removal: stap 7, afbeelding 3 van 3
    • Wedge a tire lever between the tire and the rim. Grab the tire with the lever's inward scoop.
    • Grab the tire's edge with the lever and pull it back to scoop the tire from the rim.
    • Keep the tire lever anchored on a spoke with the notch on the lever's opposite end.
  8. Nishiki Aero II Tire Removal: stap 8, afbeelding 1 van 2 Nishiki Aero II Tire Removal: stap 8, afbeelding 2 van 2
    • Repeat with an additional tire lever five inches away from the other.
  9. Nishiki Aero II Tire Removal: stap 9, afbeelding 1 van 3 Nishiki Aero II Tire Removal: stap 9, afbeelding 2 van 3 Nishiki Aero II Tire Removal: stap 9, afbeelding 3 van 3
    • Repeat with a third tire lever farther around the tire.
    • Alternate lifting the second and third levers until the tire comes partway off.
  10. Nishiki Aero II Tire Removal: stap 10, afbeelding 1 van 3 Nishiki Aero II Tire Removal: stap 10, afbeelding 2 van 3 Nishiki Aero II Tire Removal: stap 10, afbeelding 3 van 3
    • Wedge the tire off of the other rim with the tire levers.
    • Pull the air valve from its hole in the rim to completely remove the tire.
Conclusie
Tobias Elder
113 Reputatie
7 handleidingen geschreven
Cal Poly, Team 21-53, Johann Spring 2013 Lid van Cal Poly, Team 21-53, Johann Spring 2013
CPSU-JOHANN-S13S21G53
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 20
Altijd: 1,225
