Inleiding
This guide will walk you through how to quickly and efficiently remove the tire from your Nishiki Aero II bicycle in five simple steps! This guide may be used to help you remove damaged or flat tires for replacement! Before you begin, there is no special skills needed for this removal. All you need is to familiarize yourself with the tools listed and get started!
Wat je nodig hebt
Unscrew the cap from the air valve.
Release the tire's air by pressing a thin object on the center pin of the valve.
