Ga door naar hoofdinhoud
Nintendo Wii Remote Disassembly and Corrosion Cleaning
Wat je nodig hebt
  1. Nintendo Wii Remote Disassembly and Corrosion Cleaning, Nintendo Wii Remote Disassembly and Corrosion Cleaning: stap 1, afbeelding 1 van 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning, Nintendo Wii Remote Disassembly and Corrosion Cleaning: stap 1, afbeelding 2 van 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning, Nintendo Wii Remote Disassembly and Corrosion Cleaning: stap 1, afbeelding 3 van 3
    • Remove the battery cover and the batteries.
    • Remove the four tri-point Y1 screws holding the remote together.
  2. Nintendo Wii Remote Disassembly and Corrosion Cleaning: stap 2, afbeelding 1 van 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: stap 2, afbeelding 2 van 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: stap 2, afbeelding 3 van 3
    • Using an opening tool, apply pressure to the tabs located near the "A" button.
    • The tabs can break, but the remote will still work even if they do break.
    • Remove the faceplate.
  3. Nintendo Wii Remote Disassembly and Corrosion Cleaning: stap 3, afbeelding 1 van 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: stap 3, afbeelding 2 van 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: stap 3, afbeelding 3 van 3
    • To remove the motherboard, press up on the "B" button, and then the connector at the bottom.
  4. Nintendo Wii Remote Disassembly and Corrosion Cleaning: stap 4, afbeelding 1 van 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: stap 4, afbeelding 2 van 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: stap 4, afbeelding 3 van 3
    • Unclip the tabs to remove the plastic piece.
    • On the back, move the vibration motor out of the way to completely remove the plastic piece.
  5. Nintendo Wii Remote Disassembly and Corrosion Cleaning: stap 5, afbeelding 1 van 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: stap 5, afbeelding 2 van 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: stap 5, afbeelding 3 van 3
    • Find any corrosion on the motherboard.
    • Corrosion on the motherboard will have a blueish color and may appear in multiple places.
    • Check the battery terminals for corrosion.
    • If batteries leaked in the remote, there will be corrosion on the terminals.
  6. Nintendo Wii Remote Disassembly and Corrosion Cleaning: stap 6, afbeelding 1 van 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: stap 6, afbeelding 2 van 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: stap 6, afbeelding 3 van 3
    • Clean the corroded areas with isopropyl alcohol and a toothbrush.
    • Q-tips can be used instead of a toothbrush.
    • Cleaning won't make look it perfect, but the remote will work again.
  7. Nintendo Wii Remote Disassembly and Corrosion Cleaning: stap 7, afbeelding 1 van 2 Nintendo Wii Remote Disassembly and Corrosion Cleaning: stap 7, afbeelding 2 van 2
    • Clean the terminals with isopropyl alcohol and a toothbrush or Q-tips.
    • It is difficult to remove this piece, so clean it as good as you can. Using more isopropyl alcohol helps here.
Conclusie
11 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Would 99% Isopropyl Alcohol also be okay to use as cleaner?
Mirela - Antwoord
Of course, I use this for cleaning every type of motherboard, the difference between 99% and 70% is that the solution contains less water, so the liquid evaporate in less time :)
ReDeath_ -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 24
Afgelopen 7 dagen: 250
Afgelopen 30 dagen: 967
Altijd: 20,025
