Ga door naar hoofdinhoud
Inleiding
Use this guide to replace a broken DVD drive.
  1. Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii. Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
    • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
  2. Remove the two 8.3 mm Tri-Wing screws hidden under the covers you just removed.
    • Remove the two 8.3 mm Tri-Wing screws hidden under the covers you just removed.
  3. Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
    • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
  4. Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
    • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
  5. Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
    • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
  6. Carefully pull the faceplate away from the front of the Wii. Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Carefully pull the faceplate away from the front of the Wii.
    • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Remove the faceplate.
  7. Open the controller port cover until it is perpendicular to the black controller port bezel. Pull the controller port cover straight up to release it from the outer case. Repeat this procedure for the memory card port cover.
    • Open the controller port cover until it is perpendicular to the black controller port bezel.
    • Pull the controller port cover straight up to release it from the outer case.
    • Repeat this procedure for the memory card port cover.
  8. Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel. Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
    • Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
    • Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
  9. Remove the two 5 mm Phillips screws above the controller ports.
    • Remove the two 5 mm Phillips screws above the controller ports.
  10. Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
    • Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
  11. Remove the following screws:
    • Remove the following screws:
    • Two 5 mm Phillips screws
    • One 8.2 mm Tri-Wing screw
  12. Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
    • Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
  13. Remove the two 8.2 mm Tri-Wing screws hidden under the feet you just removed.
    • Remove the two 8.2 mm Tri-Wing screws hidden under the feet you just removed.
  14. Lift the outer case straight up off the body of the Wii.
    • Lift the outer case straight up off the body of the Wii.
  15. Remove the small Phillips screw securing the battery door to the bottom panel. This screw is captive to the battery door.
    • Remove the small Phillips screw securing the battery door to the bottom panel.
    • This screw is captive to the battery door.
    • Pull the battery door out of the Wii.
    • This is a good time to change the CR2032 battery if it hasn't been changed recently.
  16. Remove the 8.2 mm Tri-Wing screw that was hidden beneath the battery door.
    • Remove the 8.2 mm Tri-Wing screw that was hidden beneath the battery door.
  17. Remove the two 8.2 mm Tri-Wing screws securing the DVD drive shield near the controller ports.
    • Remove the two 8.2 mm Tri-Wing screws securing the DVD drive shield near the controller ports.
  18. Lift the DVD drive shield upward and remove it from the Wii.
    • Lift the DVD drive shield upward and remove it from the Wii.
  19. Remove the four 9 mm #1 Phillips screws securing the DVD drive to the bottom panel.
    • Remove the four 9 mm #1 Phillips screws securing the DVD drive to the bottom panel.
  20. Lift the side of the DVD drive opposite the controller ports enough to access the cables on its bottom face.
    • Lift the side of the DVD drive opposite the controller ports enough to access the cables on its bottom face.
    • Carefully pull the DVD drive power cable out from under the plastic shroud near the heat sink.
  21. Pull the DVD drive power cable away from its socket on the DVD drive.
    • Pull the DVD drive power cable away from its socket on the DVD drive.
  22. Use your fingernail to flip up the retaining flap on the DVD drive ribbon cable socket. Be sure you are prying up on the retaining flap, not the socket itself.
    • Use your fingernail to flip up the retaining flap on the DVD drive ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the DVD drive ribbon cable out of its socket.
    • Remove the DVD drive from the Wii.
Conclusie
38 andere personen hebben deze handleiding voltooid.
My problem was an object that had been lodged in the drive - in fact, I didn't need to replace the drive. I successfully followed thru step 19, and at that point, I was able to extract the foreign object through the gaps in the disc housing. Then I reversed the steps through to the start and everything is working again.
JJones - Antwoord
I used this to access the drive area where I successfully identified and removed a plastic toy 50p coin my 2 yr old had carefully inserted in it; The Wii works again now
I am v gratefuil for these excellent instructions
And a tip - use a computer/laptop to view; an iphone was a wee (Wii?) bit too small!
david simpson - Antwoord
You can also download our free iPad app.
David Hodson -
Your instructions were very thorough, and my Wii now works again, thanks!
Robotai - Antwoord
I’ve replaced the drive & receive the same error.
it doesn’t appear to read the disc.
Could it be the ribbon cable needs checking or
do you need to run a WII update as the device realises a hardware change and it won’t work until
an update has been run.
Brendon J - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 63
Afgelopen 30 dagen: 204
Altijd: 109,883
