Inleiding
The motherboard is the central hub of all components and ports in your device. If multiple components and ports are not working properly, the motherboard in your device may not be functioning and may need replacement.
Please read all instructions in each step before continuing to disassemble and replace the motherboard.
Wat je nodig hebt
Using the Phillips #0 screwdriver, remove the single screw from the bottom of the device.
Pull out the slot with the battery (pictured in the third photo). Leave both the battery and the slot organized on the side with the removed screw.
Using your fingers, gently detach the Wi-Fi board from the motherboard.
