Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Nintendo WaveBird Wireless Controller Joystick Replacement
Wat je nodig hebt
  1. Nintendo WaveBird Wireless Controller Joystick Replacement, Batteries: stap 1, afbeelding 1 van 2 Nintendo WaveBird Wireless Controller Joystick Replacement, Batteries: stap 1, afbeelding 2 van 2
    • Pull down on the battery cover release lever and pull back to remove the cover.
  2. Nintendo WaveBird Wireless Controller Joystick Replacement: stap 2, afbeelding 1 van 1
    • Remove both batteries from the device.
  3. Nintendo WaveBird Wireless Controller Joystick Replacement, Front Panel: stap 3, afbeelding 1 van 2 Nintendo WaveBird Wireless Controller Joystick Replacement, Front Panel: stap 3, afbeelding 2 van 2
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
  4. Nintendo WaveBird Wireless Controller Joystick Replacement: stap 4, afbeelding 1 van 2 Nintendo WaveBird Wireless Controller Joystick Replacement: stap 4, afbeelding 2 van 2
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
  5. Nintendo WaveBird Wireless Controller Joystick Replacement, Buttons: stap 5, afbeelding 1 van 3 Nintendo WaveBird Wireless Controller Joystick Replacement, Buttons: stap 5, afbeelding 2 van 3 Nintendo WaveBird Wireless Controller Joystick Replacement, Buttons: stap 5, afbeelding 3 van 3
    • Use tweezers to remove the buttons.
    • It may be easier to remove the A button off of the pad by lifting it with your fingers.
    • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
  6. Nintendo WaveBird Wireless Controller Joystick Replacement, Joystick: stap 6, afbeelding 1 van 2 Nintendo WaveBird Wireless Controller Joystick Replacement, Joystick: stap 6, afbeelding 2 van 2
    • Grab the base of the grey joystick cover with one hand and firmly hold down the rest of the controller with the other hand.
    • Pull off the grey joystick cover.
    • During reassembly, make sure the slots inside the joystick cover line up with the motherboard so it can fit back together.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Garrett Leung
955 Reputatie
8 handleidingen geschreven
Cal Poly, Team 10-40, Amido Spring 2013 Lid van Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Leden
37 handleidingen geschreven
Één opmerking
Question. My wavebird joystick wobbles a lot and gets stuck in directions I’m not inputting. Will replacing the top of the stick fix this? Or would I have to solder a new analog stick to the board?
Golgamang - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 51
Altijd: 9,488
