Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
This guide will show you the steps on installing the joystick. This will be helpful if the joystick isn't working properly.
Wat je nodig hebt
Pull down on the battery cover release lever and pull back to remove the cover.
Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
Grab the base of the grey joystick cover with one hand and firmly hold down the rest of the controller with the other hand.
Pull off the grey joystick cover.
7 andere personen hebben deze handleiding voltooid.
