Ga door naar hoofdinhoud
Inleiding
This guide will help you remove the front panel of the controller. It is a prerequisite guide only.
Onderdelen
Geen onderdelen opgegeven.
  1. Pull down on the battery cover release lever and pull back to remove the cover. Pull down on the battery cover release lever and pull back to remove the cover.
    • Pull down on the battery cover release lever and pull back to remove the cover.
  2. Remove both batteries from the device.
    • Remove both batteries from the device.
  3. Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver. During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
  4. Carefully turn over the controller and place it on a flat surface. Slowly separate the top panel from the bottom panel.
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
Conclusie
JT Gryder
78 Reputatie
1 Handleiding geschreven
Cal Poly, Team 10-40, Amido Spring 2013 Lid van Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Leden
31 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 1,115
