Inleiding
Follow this guide to replace a broken or faulty circuit board in your Nintendo Switch dock.
Required Tools: Tri-head 360x50 driver, mini-tweezers, needle-nose pliers
Wat je nodig hebt
Unclip the back plate. It will fold back to expose the power wire and the HDMI cable.
Remove the Switch from the dock
Orient the dock so that the adapter block faces up like shown
Gereedschap gebruikt in deze stap:Tweezers$4.99
Using a Tri-head 360x50 driver, unscrew the four screws shown (1, 2, 3, 4) and use mini-tweezers to remove the screws
Place the screws in a secure location where you will remember to get them later.
Using Tri-head 360x50 driver, unscrew the next four screws shown (A, B, C, D) and use the mini-tweezers to remove the screws.
Place the screws in a secure location.
Indicating the length of the screws for steps three and four would be very helpful, they are different lengths and I can't remember which ones go where and this guide is of no help with that.
If anyone checks these comments I'm having the same issue. There are 4 of each and I don't know which step has the long screws and which has the short ones.
Carefully pull to remove the backing from the switch dock, exposing the circuit board.
Carefully unplug the red and black cable connecting the circuit board with the dock housing
This cable can be more easily removed with a pair of needle-nosed pliers. Clamp on to the plastic casing and gently pull to remove the cable
Gently pull the film cable out of the circuit board. The cable should slide free when lightly pulled.
alternatively, there is a hinged clip that holds it. Lift on the light grey bar to open and close the hinge holding the ribbon connector head in place.
This section should be updated to tell user that they need to lift up the latch on the ZIF socket. Lightly pulling it won't release the ribbon cable.
Unpack and inspect replacement circuit board - check for any damage or faults
Carefully reconnect the film cable to the replacement circuit board. The cable should slide in when gentle pressure is applied.
Ensure the cable is oriented correctly before insertion to avoid damage.
Make sure the cable is oriented correctly - you can check the port to make sure the holes will line up correctly
Align plug - end of cable to port and apply gentle pressure. The cable should slide back into place.
The circuit board should fit without obstruction.
Gently apply pressure to the circuit board to ensure it seats into the housing.
Place backing onto dock. All screw holes should line up.
Apply gentle pressure. (You should feel a slight "give" as it seats properly)
Use Tri-Head driver to reinsert screws (A, B, C, D)
Use Tri-head driver to reinsert screws (1, 2, 3, 4)
Plug HDMI cable into a device with an HDMI port (TV, monitor, computer, etc.) (NOTE: need adapter for PC for video and audio connection)
Insert Nintendo Switch into dock and turn it on.
The dock should charge your switch. If it doesn't, check the power supply/power cable
When correctly seated in the dock, the Switch screen will remain black
Use Switch normally to test audio and video output
If Switch works normally but the dock doesn't, check to make sure the following are true:
Both cables are plugged in correctly
Both cables are not obstructed or damaged
Circuit board is not damaged
Circuit board seats correctly into housing
All electrical equipment should be stored safely out of the way of hazards. After replacement, the Switch Dock should function properly.
11 andere personen hebben deze handleiding voltooid.
5 opmerkingen
At https://www.hollywood-docks.com, we specialize in new dock installations, existing dock repairs and updates, seawall installations and repairs, deck and patio construction, and much more. We pride ourselves on providing high-quality craftsmanship and exceptional customer service.
Wrong kind of dock, bro.
modtang -
