Ga door naar hoofdinhoud
Nintendo Super Famicom SHVC-001 Cartridge Port Replacement
Wat je nodig hebt
  1. Nintendo Super Famicom SHVC-001 Cartridge Port Replacement, Upper Case: stap 1, afbeelding 1 van 1
    • Remove the six 13.5 mm screws on the lower case with a 4.5 mm Gamebit screwdriver.
  2. Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: stap 2, afbeelding 1 van 2 Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: stap 2, afbeelding 2 van 2
    • Flip the Famicom over and set it down.
    • Lift off the upper case.
  3. Nintendo Super Famicom SHVC-001 Cartridge Port Replacement, Cartridge Port: stap 3, afbeelding 1 van 1
    • Remove the mechanism by lifting the axle slightly to the right and drawing it out.
    • A tiny spring holds the mechanism back in place. It's not too tense, but take care not to lose it. Also, take note of how it is arranged for future reassembly.
  4. Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: stap 4, afbeelding 1 van 2 Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: stap 4, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the two screws that secure the power switch.
    • The power switch is connected to the main board via a little plastic connection; grip the motherboard connector and pull it straight out of its port.
    • Do not pull on the wires to avoid harming them. Instead, pull on the plastic connector.
  5. Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: stap 5, afbeelding 1 van 3 Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: stap 5, afbeelding 2 van 3 Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: stap 5, afbeelding 3 van 3
    • Carefully pull the ribbon cable that is attached to the controller board and the main board.
    • Remove the controller port.
  6. Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: stap 6, afbeelding 1 van 2 Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: stap 6, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the six 15.6 mm screws that secure the silver protective shield.
    • Remove the silver shield.
  7. Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: stap 7, afbeelding 1 van 2 Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: stap 7, afbeelding 2 van 2
    • Lift the cartridge slot up and out of the device.
  8. Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: stap 8, afbeelding 1 van 2 Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: stap 8, afbeelding 2 van 2
    • If the contacts are rusted or corroded, use a cotton swab damp with high-concentration isopropyl alcohol to remove the rust.
  9. Nintendo Super Famicom SHVC-001 Cartridge Port Replacement: stap 9, afbeelding 1 van 1
    • Replace the cartridge slot.
Conclusie
Carter Eason
454 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 44
Altijd: 79
