Ga door naar hoofdinhoud
Nintendo GameCube Top Case Replacement
Wat je nodig hebt
  1. Nintendo GameCube Top Case Replacement, Top Case: stap 1, afbeelding 1 van 3 Nintendo GameCube Top Case Replacement, Top Case: stap 1, afbeelding 2 van 3 Nintendo GameCube Top Case Replacement, Top Case: stap 1, afbeelding 3 van 3
    • Turn over the Gamecube so that the bottom side is facing up.
    • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
  2. Nintendo GameCube Top Case Replacement: stap 2, afbeelding 1 van 3 Nintendo GameCube Top Case Replacement: stap 2, afbeelding 2 van 3 Nintendo GameCube Top Case Replacement: stap 2, afbeelding 3 van 3
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
    • Move the GameCube so that the inside is facing upwards.
    This can also be done whilst being in the normal upright position after all 4 of the 4.5mm Gamebit screws have been removed. Pull the top of the shell directly upwards and it should slide off easily.
    Less chance of snagging any wires or parts.
    Christopher Cox - Antwoord
Conclusie
13 andere personen hebben deze handleiding voltooid.
dcarlin
301 Reputatie
4 handleidingen geschreven
Cal Poly, Team 6-2, Maness Fall 2009 Lid van Cal Poly, Team 6-2, Maness Fall 2009
CPSU-MANESS-F09S6G2
4 Leden
45 handleidingen geschreven
Één opmerking
Can you do a more in-depth version of the top cover? I had to clean each piece and need help figuring out where all the pieces go. Thanks
JJ Jackson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 28
Afgelopen 30 dagen: 154
Altijd: 24,541
