Ga door naar hoofdinhoud
Inleiding
This guide will teach you how to disassemble the GameCube Optical Drive Assembly for the purpose of accessing the Optical Drive and the laser. These parts are responsible for reading the information off of the game discs which allows games to be played on the console.
If the Optical Drive malfunctions (fails to spin the disc for example) or the Optical Laser Lens is damaged, it can prevent the game discs from being read properly. This can warrant a replacement of the device part. As the GameCube is an older console, E-bay would be a good place to start when searching for a replacement part.
Before attempting the disassembly, you will need a 4.5 mm Gamebit screwdriver. This is special tool that is used to open certain Nintendo consoles and can be ordered online from Amazon.
  1. Nintendo GameCube Optical Drive Assembly Replacement, Top Case: stap 1, afbeelding 1 van 3 Nintendo GameCube Optical Drive Assembly Replacement, Top Case: stap 1, afbeelding 2 van 3 Nintendo GameCube Optical Drive Assembly Replacement, Top Case: stap 1, afbeelding 3 van 3
    • Turn over the Gamecube so that the bottom side is facing up.
    • Locate the four screws (circled in red) on each corner of the device. Then, use a 4.5 mm Gamebit screwdriver to remove all four screws.
  2. Nintendo GameCube Optical Drive Assembly Replacement: stap 2, afbeelding 1 van 3 Nintendo GameCube Optical Drive Assembly Replacement: stap 2, afbeelding 2 van 3 Nintendo GameCube Optical Drive Assembly Replacement: stap 2, afbeelding 3 van 3
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half. Then place the inside of the unit facing up.
    This can also be done whilst being in the normal upright position after all 4 of the 4.5mm Gamebit screws have been removed. Pull the top of the shell directly upwards and it should slide off easily.
    Less chance of snagging any wires or parts.
    Christopher Cox - Antwoord
  3. Nintendo GameCube Optical Drive Assembly Replacement, Front and Back Panel: stap 3, afbeelding 1 van 1
    • Gently press down on the clips located on either side of the the back panel, as shown, and carefully remove it from the main part of the device.
    A second picture clearly showing which direction to pull the back panel away from the unit would be nice.
    rubixtriangle - Antwoord
  4. Nintendo GameCube Optical Drive Assembly Replacement: stap 4, afbeelding 1 van 1
    • With the back panel removed, carefully unclip the controller ports at the front of the unit.
    • A ribbon cable (outlined in orange) is still attached to the unit. Do Not Disconnect This Cable.
    • Controller ports are where the controllers plug into the game console, and are a half circular shape.
    well... what happens if accidentally i disconnected it?
    negroporexcelencia - Antwoord
    presumably nothing major. The CMOS battery is attached to the controller ports, so the most i'd expect is that the gamecube loses it's date/time setting. As long as you reset that before jumping into animal crossing or something, you should be fine. I'm currently doing a teardown of my gamecube, and if something does prove to have gone wrong, i'll report back.
    sigoshi -
    okay, i finished putting it back together. gamecube works fine and surprisingly still remembers what year it is. boots into smash bros and shows memory card contents fine.
    sigoshi -
  5. Nintendo GameCube Optical Drive Assembly Replacement: stap 5, afbeelding 1 van 2 Nintendo GameCube Optical Drive Assembly Replacement: stap 5, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the two 2 screws (circled in red) that are located on the back of the control port.
    • Carefully separate the gray outer casing of the control port and the circuit board.
    That step is not needed for the laser replacement.
    Vincent Léon - Antwoord
  6. Nintendo GameCube Optical Drive Assembly Replacement, Optical Drive Assembly: stap 6, afbeelding 1 van 2 Nintendo GameCube Optical Drive Assembly Replacement, Optical Drive Assembly: stap 6, afbeelding 2 van 2
    • The left side of the unit contains the cooling fan and its housing. Carefully remove the two (2) screws attaching the cooling fan housing to the unit.
    • Do not detach the red and black cooling fan wire from the main unit.(red/black wire)
  7. Nintendo GameCube Optical Drive Assembly Replacement: stap 7, afbeelding 1 van 2 Nintendo GameCube Optical Drive Assembly Replacement: stap 7, afbeelding 2 van 2
    • Remove the four (4) Phillips #1 screws retaining the ground springs
    • Carefully remove the ground springs from the main unit as shown in the second photograph.
  8. Nintendo GameCube Optical Drive Assembly Replacement: stap 8, afbeelding 1 van 2 Nintendo GameCube Optical Drive Assembly Replacement: stap 8, afbeelding 2 van 2
    • The optical drive is secured to a metal plate.
    • Using a Phillips #2 screwdriver, unscrew the twelve (12) screws that are around the outer edge of the optical drive (circled in red).
    Are these 12 screws the exact same kind like the 2 that were on the fan?
    blaise ventura - Antwoord
    Yes! As far as I can tell anyway. Makes sense, too since opposite the fan you have five of the same holes as well.
    Ben Zelinsky - Antwoord
  9. Nintendo GameCube Optical Drive Assembly Replacement: stap 9, afbeelding 1 van 3 Nintendo GameCube Optical Drive Assembly Replacement: stap 9, afbeelding 2 van 3 Nintendo GameCube Optical Drive Assembly Replacement: stap 9, afbeelding 3 van 3
    • Carefully separate the optical drive assembly from the rest of the GameCube unit.
    • The optical drive assembly is secured to the motherboard underneath by a slot; some force may be required to carefully free the assembly.
    • The metal plate and the actual optical drive will remain attached (picture 3).
  10. Nintendo GameCube Optical Drive Assembly Replacement, Optical Drive Assembly: stap 10, afbeelding 1 van 3 Nintendo GameCube Optical Drive Assembly Replacement, Optical Drive Assembly: stap 10, afbeelding 2 van 3 Nintendo GameCube Optical Drive Assembly Replacement, Optical Drive Assembly: stap 10, afbeelding 3 van 3
    • At this point, your optical drive assembly should be separated from your GameCube (picture 1).
    • Flip the optical drive assembly upside down
    • Shown in picture 2, remove the 6 Phillips #1 screws with a philips screwdriver.
    • Once the screws are removed, gently lift and remove the metal plate (shown in picture 3).
    • Be careful not to disturb the brown ribbon cable (highlighted in the yellow).
  11. Nintendo GameCube Optical Drive Assembly Replacement: stap 11, afbeelding 1 van 3 Nintendo GameCube Optical Drive Assembly Replacement: stap 11, afbeelding 2 van 3 Nintendo GameCube Optical Drive Assembly Replacement: stap 11, afbeelding 3 van 3
    • Remove the blue wire by gently pulling.
    • Disconnect the Brown cable. This is done by gently pulling the black tab away from the white plastic. This will loosen the tension on the brown cable allowing it to gently be slid away from the tab.
    • Shown in the third picture, remove the 4 Phillips #1 screws connecting the circuit board to the optical drive assembly.
    • The fourth screw is located behind the screwdriver in the third picture (highlighted in the orange circle).
    A helpful addition/change to this step would be to include a photo of where/how to remove the brown ribbon cable (maybe also include this terminology in the text, instead of just “cable”). Furthermore, the yellow box to indicate the blue cable highlights everything except the part that you need to remove, which is a little confusing.
    Thanks!
    Ben
  12. Nintendo GameCube Optical Drive Assembly Replacement: stap 12, afbeelding 1 van 3 Nintendo GameCube Optical Drive Assembly Replacement: stap 12, afbeelding 2 van 3 Nintendo GameCube Optical Drive Assembly Replacement: stap 12, afbeelding 3 van 3
    • Gently remove the circuit board (the large green square) as shown in the three pictures.
    • DO NOT SEPARATE the red wire or the white ribbon cable connecting the circuit board to the metal plate.
    • Red Wire
    • White ribbon Cable
    What would happen if I accidentally separated the white ribbon cable... because I watched a video of some guy going through this same process. Separated all the cables and his worked. My cube stopped reading disks recently. Laser is calibrated properly. Begins to spin then stops
    Ps
    Is there anyway I can save my cube
    kyleharms10 - Antwoord
    I'm just guessing here, but I think they mean there's no need to separate those cables to complete the repair—just be careful not to pull or stress them. Like you said, nothing bad will happen if you choose to disconnect a couple cables. As for what's wrong with your cube, you might want to try asking your question over in the Answers forum.
    Jeff Suovanen -
    There is a small tab to the left of the red wire that you need to pull out to release the circuit board.
    patriotsfansince87 - Antwoord
    Why do we need further disassembly that this ? The potentiometer is already accessible at this point. Why do we need to tear down the lens from it’s slot in step 16 ?
    Startide Harlock - Antwoord
    Good question! I’m wondering the same thing.
    Ben Zelinsky -
    You don’t. You can stop here if you’re doing the laser potentiometer calibration.
    jweeman -
  13. Nintendo GameCube Optical Drive Assembly Replacement: stap 13, afbeelding 1 van 3 Nintendo GameCube Optical Drive Assembly Replacement: stap 13, afbeelding 2 van 3 Nintendo GameCube Optical Drive Assembly Replacement: stap 13, afbeelding 3 van 3
    • Use a flathead screwdriver to carefully release the four plastic clips holding the drive assembly together.
    • The last clip can be rather hard to find. Carefully use a screwdriver as leverage to unscrew and release the last clip, which is highlighted in blue (Picture 3).
    Since this step uses a flathead screwdriver, it might be useful to include that in the list of required tools at the top.
  14. Nintendo GameCube Optical Drive Assembly Replacement: stap 14, afbeelding 1 van 3 Nintendo GameCube Optical Drive Assembly Replacement: stap 14, afbeelding 2 van 3 Nintendo GameCube Optical Drive Assembly Replacement: stap 14, afbeelding 3 van 3
    • Gently lift the metal plate off of the drive assembly (shown in the first picture).
    • Be careful not to sever the red wire or the white ribbon cable still attached to the two halves of the drive assembly.
    • Then flip the two halves of the drive assembly upside down as shown in the third picture.
  15. Nintendo GameCube Optical Drive Assembly Replacement: stap 15, afbeelding 1 van 3 Nintendo GameCube Optical Drive Assembly Replacement: stap 15, afbeelding 2 van 3 Nintendo GameCube Optical Drive Assembly Replacement: stap 15, afbeelding 3 van 3
    • Use a flathead screwdriver to release the two clips located on the back half of the drive assembly.
    • The final clip doesn't need to be released; the top half of the drive assembly will slide away from the lower half.
    • Finish removing the top half of the drive assembly from the base.
    • Be careful not to detach the red wire or the white ribbon cable still attached.
  16. Nintendo GameCube Optical Drive Assembly Replacement: stap 16, afbeelding 1 van 2 Nintendo GameCube Optical Drive Assembly Replacement: stap 16, afbeelding 2 van 2
    • Once the top half of the drive assembly is detached, turn it upside down.
    • Using a philips screwdriver, carefully remove the 3 final screws located near the bars of the lens assembly.
    • Once the the three final screws are removed, the lens assembly can be extracted (as shown in the second picture).
    what kind of screws are these on the laser lens i lost one and need to buy new ones cause i cant find the 3rd
    Ugly potato - Antwoord
Conclusie
16 andere personen hebben deze handleiding voltooid.
mwbisson
946 Reputatie
3 handleidingen geschreven
Cal Poly, Team 6-2, Maness Fall 2009 Lid van Cal Poly, Team 6-2, Maness Fall 2009
CPSU-MANESS-F09S6G2
4 Leden
37 handleidingen geschreven
4 Opmerkingen
What type of optical drive could I use to replace the one in said GameCube once I've broken it down?
Bob Marotta - Antwoord
Did you ever find out, Bob?
Lee Martin -
I found OEM parts (removed from other Game Cubes) available on Ebay. Just ordered the part for about $16.
erin clark - Antwoord
Good walkthrough. My 8 year old completed this repair with minimal help from me. Thanks!
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 17
Afgelopen 7 dagen: 107
Afgelopen 30 dagen: 527
Altijd: 44,854
