Inleiding
This guide will teach you how to remove the existing GameCube motherboard and replace it with a new one.
Onderdelen
Geen onderdelen opgegeven.
Turn over the Gamecube so that the bottom side is facing up.
Locate the four screws (circled in red) on each corner of the device. Then, use a 4.5 mm Gamebit screwdriver to remove all four screws.
Gently press down on the clips located on either side of the the back panel, as shown, and carefully remove it from the main part of the device.
The left side of the unit contains the cooling fan and its housing. Carefully remove the two (2) screws attaching the cooling fan housing to the unit.
Do not detach the red and black cooling fan wire from the main unit.(red wire)
With the Optical Drive Assembly removed, your GameCube should now look like this.
Remove the 6 screws (circled in orange) on the heat sink using a #1 Phillips screwdriver.
10 andere personen hebben deze handleiding voltooid.
3 Opmerkingen
What happens if you disconnect that cable (localizated on Step 4)?
Its soldered to the front-board and the connector is on the main-board under the disc assembly, trying to remove it will break it.
I have been having trouble with my cube shorting out when I insert a memory card into slot A. What is the best way to get at it see if this is the case, and what should I be looking for?
Many thanks
