Ga door naar hoofdinhoud
Nintendo GameCube Controller Directional Pad Replacement
Wat je nodig hebt
  1. Nintendo GameCube Controller Directional Pad Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
  2. Nintendo GameCube Controller Directional Pad Replacement: stap 2, afbeelding 1 van 1
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
  3. Nintendo GameCube Controller Directional Pad Replacement, Z Button: stap 3, afbeelding 1 van 2 Nintendo GameCube Controller Directional Pad Replacement, Z Button: stap 3, afbeelding 2 van 2
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
  4. Nintendo GameCube Controller Directional Pad Replacement, Circuit Board: stap 4, afbeelding 1 van 1
    • Carefully unhook the cable that is looped around the peg.
  5. Nintendo GameCube Controller Directional Pad Replacement: stap 5, afbeelding 1 van 1
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
  6. Nintendo GameCube Controller Directional Pad Replacement, Directional Pad: stap 6, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Remove the rubber backing with tweezers.
  7. Nintendo GameCube Controller Directional Pad Replacement: stap 7, afbeelding 1 van 1
    • Use tweezers to grab the center peg of the directional pad and lift it out of its socket.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Sean Michel
2.600 Reputatie
8 handleidingen geschreven
Cal Poly, Team 19-44, Regan Winter 2013 Lid van Cal Poly, Team 19-44, Regan Winter 2013
CPSU-REGAN-W13S19G44
4 Leden
32 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 43
Altijd: 7,364
