Ga door naar hoofdinhoud
Nintendo GameCube Controller Buttons Replacement
Wat je nodig hebt
  1. Nintendo GameCube Controller Buttons Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
  2. Nintendo GameCube Controller Buttons Replacement: stap 2, afbeelding 1 van 1
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
    For some reason, it was simpler to take the top half off, although it could be because it is most probably refurbished before
    Rukir Gaming - Antwoord
  3. Nintendo GameCube Controller Buttons Replacement, Z Button: stap 3, afbeelding 1 van 2 Nintendo GameCube Controller Buttons Replacement, Z Button: stap 3, afbeelding 2 van 2
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
    So how do you put it back in like the replacement because I have a controller I'm working a junker my Friend gave me and I'm trying to fix it the z button doesn't work here it's a pelican wireless controller it's actually not to bad bulky but not bad
    Justin Sebastian - Antwoord
  4. Nintendo GameCube Controller Buttons Replacement, Circuit Board: stap 4, afbeelding 1 van 1
    • Carefully unhook the cable that is looped around the peg.
    Um can soneone explain the peg and cable part? I dont understand it...
    Tyler Goamez - Antwoord
    I would say that the cable is somehow "hooked" to the case and you have to get the cable away from the case so that you can pull out the board
    My1 -
  5. Nintendo GameCube Controller Buttons Replacement: stap 5, afbeelding 1 van 1
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
  6. Nintendo GameCube Controller Buttons Replacement, Buttons: stap 6, afbeelding 1 van 2 Nintendo GameCube Controller Buttons Replacement, Buttons: stap 6, afbeelding 2 van 2
    • Remove the rubber backing that covers the buttons.
  7. Nintendo GameCube Controller Buttons Replacement: stap 7, afbeelding 1 van 3 Nintendo GameCube Controller Buttons Replacement: stap 7, afbeelding 2 van 3 Nintendo GameCube Controller Buttons Replacement: stap 7, afbeelding 3 van 3
    • Use tweezers to lift buttons out of their sockets.
    • When putting the buttons back, make sure the slots properly fit back together.
Conclusie
18 andere personen hebben deze handleiding voltooid.
Sean Michel
2.496 Reputatie
8 handleidingen geschreven
Cal Poly, Team 19-44, Regan Winter 2013 Lid van Cal Poly, Team 19-44, Regan Winter 2013
CPSU-REGAN-W13S19G44
4 Leden
26 handleidingen geschreven
3 opmerkingen
Is there a way I can buy the buttons separably? I lost a the X button and it's gone missing and i wanna buy one :(
tp4yourbunghole - Antwoord
u can either get a 2 dollar full button set on ebay by searching ngc buttons or u can buy from battle beaver customs for 1 dollar
dariuscorrfz - Antwoord
How do you put the back back on?
Steven Enns - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 41
Afgelopen 30 dagen: 139
Altijd: 29,154
