Ga door naar hoofdinhoud
Nintendo Game Boy Advance SP Buttons Replacement
Wat je nodig hebt
  1. Nintendo Game Boy Advance SP Buttons Replacement, Battery: stap 1, afbeelding 1 van 1
    • Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
    Quel est le nom du vis svp je l'ai perdu et j'ai pas la référence
    la chaîne de Samarium - Antwoord
    Bonjour @lachainede96340 D'après les instructions du tutoriel, il s'agit d'une vis Phillips (ou cruciforme) #00 de 4 mm de long. Ces mesures devraient suffire pour trouver une vis de remplacement dans votre stock de vis ou en magasin le cas échéant.
    Claire Miesch -
  2. Nintendo Game Boy Advance SP Buttons Replacement: stap 2, afbeelding 1 van 1
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  3. Nintendo Game Boy Advance SP Buttons Replacement: stap 3, afbeelding 1 van 1
    • Use your fingers or a plastic opening tool to remove the battery from the device.
    • Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
  4. Nintendo Game Boy Advance SP Buttons Replacement, Back Cover: stap 4, afbeelding 1 van 2 Nintendo Game Boy Advance SP Buttons Replacement, Back Cover: stap 4, afbeelding 2 van 2
    • Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
    • Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
  5. Nintendo Game Boy Advance SP Buttons Replacement: stap 5, afbeelding 1 van 1
    • Lift the back cover off of the device.
    • Potential for device damage: These inner components are vulnerable to static electricity. Exercise caution when handling these next steps to prevent damaging the device.
    • Look out for the power switch that can fall out when taking the back cover off.
  6. Nintendo Game Boy Advance SP Buttons Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • Using a Phillips #00 screwdriver, remove the three Phillips #00 4 mm long screws that hold the motherboard to the button panel.
    C'est à combien la carte mère?
    Marcel Adigbli - Antwoord
  7. Nintendo Game Boy Advance SP Buttons Replacement: stap 7, afbeelding 1 van 1
    • Be careful not to tear the ribbon cable that's connected to the screen. If you tear it, games will not appear on the device's screen!
    • Flip the motherboard up and rest it on the other half of the device, so that the back of the buttons are visible as seen in the picture.
    My Game Boy Advance SP has a problem where it won’t charge the device. The Game Boy is plugged in but the charge light does not go on. How may I turn it back on? What, inside the system, needs to be fixed? Is it one of the cables behind the charging socket inside the Game Boy?
    Connor Hutton - Antwoord
  8. Nintendo Game Boy Advance SP Buttons Replacement, Removing the Trackpads: stap 8, afbeelding 1 van 3 Nintendo Game Boy Advance SP Buttons Replacement, Removing the Trackpads: stap 8, afbeelding 2 van 3 Nintendo Game Boy Advance SP Buttons Replacement, Removing the Trackpads: stap 8, afbeelding 3 van 3
    • Using your fingers, gently lift and remove the trackpads covering the following:
    • 'A' and 'B' buttons
    • Directional Control Button Pad
    • 'Start' and 'Select' buttons
  9. Nintendo Game Boy Advance SP Buttons Replacement, Buttons: stap 9, afbeelding 1 van 3 Nintendo Game Boy Advance SP Buttons Replacement, Buttons: stap 9, afbeelding 2 van 3 Nintendo Game Boy Advance SP Buttons Replacement, Buttons: stap 9, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Using tweezers or fingers, lift and remove:
    • Directional control button pad
    • 'Start' and 'select' buttons
Conclusie
12 andere personen hebben deze handleiding voltooid.
Jose Bautista
685 Reputatie
1 Handleiding geschreven
Cal Poly, Team 17-22, Forte Winter 2013 Lid van Cal Poly, Team 17-22, Forte Winter 2013
CPSU-FORTE-W13S17G22
4 Leden
41 handleidingen geschreven
5Gids Commentaar
Hi,
How do I fix my SP Brighter when A and B buttons are simultaneously pressed, the system turns off? Please Help! Thank you in advance!
Jikan - Antwoord
there is most likely a crack in the mother board or the battery has too much pressure placed onto it
you can fix this by changing the position of the battery and putting something to stop it from moving around so it fits tightly
Taahaco 2005 - Antwoord
HI there! My problem is that I have to press the button A harder for the action to be registered, how can I fix that?
アラン - Antwoord
The L and R buttons done work, they go in perfectly fine but would it be the 2 buttons under them that aren't working? If so then how would I remove and replace them safely
Topi2756 - Antwoord
The buttons L and R don't work, they go in fine so I'm thinking that it's the buttons on the inside that are damaged. If that is the case then how would I remove and replace them safely?
Topi2756 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 51
Afgelopen 30 dagen: 262
Altijd: 24,515
