Ga door naar hoofdinhoud
Nintendo Game Boy Advance SP Back Cover Replacement
Wat je nodig hebt
  1. Nintendo Game Boy Advance SP Back Cover Replacement, Battery: stap 1, afbeelding 1 van 1
    • Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
  2. Nintendo Game Boy Advance SP Back Cover Replacement: stap 2, afbeelding 1 van 1
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  3. Nintendo Game Boy Advance SP Back Cover Replacement: stap 3, afbeelding 1 van 1
    • Use your fingers or a plastic opening tool to remove the battery from the device.
    • Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
  4. Nintendo Game Boy Advance SP Back Cover Replacement, Back Cover: stap 4, afbeelding 1 van 2 Nintendo Game Boy Advance SP Back Cover Replacement, Back Cover: stap 4, afbeelding 2 van 2
    • Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
    • Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
  5. Nintendo Game Boy Advance SP Back Cover Replacement: stap 5, afbeelding 1 van 1
    • Lift the back cover off of the device.
    • Potential for device damage: These inner components are vulnerable to static electricity. Exercise caution when handling these next steps to prevent damaging the device.
    • Look out for the power switch that can fall out when taking the back cover off.
Conclusie
21 andere personen hebben deze handleiding voltooid.
Rocco Lattanzio
1.009 Reputatie
2 handleidingen geschreven
Cal Poly, Team 17-22, Forte Winter 2013 Lid van Cal Poly, Team 17-22, Forte Winter 2013
CPSU-FORTE-W13S17G22
4 Leden
41 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 16
Afgelopen 7 dagen: 164
Afgelopen 30 dagen: 394
Altijd: 34,819
