Ga door naar hoofdinhoud
Nintendo Family Computer (Famicom) Controller Motherboard Replacement
Wat je nodig hebt
  1. Nintendo Family Computer (Famicom) Controller Motherboard Replacement, Controller Motherboard: stap 1, afbeelding 1 van 2 Nintendo Family Computer (Famicom) Controller Motherboard Replacement, Controller Motherboard: stap 1, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the six 13.5 mm screws that secure the lower case.
    • Remove the lower case.
  2. Nintendo Family Computer (Famicom) Controller Motherboard Replacement: stap 2, afbeelding 1 van 2 Nintendo Family Computer (Famicom) Controller Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Carefully disconnect the faulty controller's connector from the motherboard port.
    • Pull only on the connector; do not pull on the wires. The connector can be quite strenuous to remove. A pry tool or pliers may be helpful to disconnect the connector.
  3. Nintendo Family Computer (Famicom) Controller Motherboard Replacement: stap 3, afbeelding 1 van 2 Nintendo Family Computer (Famicom) Controller Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the six 9.3 mm screws from the back side of the controller.
    • Remove the back cover of the controller.
  4. Nintendo Family Computer (Famicom) Controller Motherboard Replacement: stap 4, afbeelding 1 van 2 Nintendo Family Computer (Famicom) Controller Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Remove the controller motherboard, noting its orientation.
    • The Player 1 and Player 2 controller motherboards are not identical and differ from one another.
Conclusie
Trenton Saint
109 Reputatie
1 Handleiding geschreven
IUPUI, Team 2-2, Harley Spring 2024 Lid van IUPUI, Team 2-2, Harley Spring 2024
IUPUI-HARLEY-S24S2G2
4 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 28
Altijd: 71
