Inleiding
NES cover yellowed, cracked, fell out? This guide will help you get the look of the NES back in order.
Unfortunately, the cover does not come with the imprint "European Edition", but everything works as usual.
Wat je nodig hebt
Remove the six 13.50mm PH2 screws from the base plate.
Now take off the upper part of the housing.
Take the top housing and turn it over.
Remove the four 7,80mm flathead screws.
Remove both metal clips.
Pull the front black cap off upwards.
Now lift the flap out at an angle.
The new flap can now be inserted.
Work the steps in reverse order to reassemble your device.
Één andere persoon heeft deze handleiding voltooid.
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
