Inleiding
Give your DSi XL and audio edge by replacing the volume buttons.
Wat je nodig hebt
Remove the two Phillips screws securing the battery cover to the back of the handheld console.
Lift the battery cover off the back of the DSi XL.
Remove the four rubber screw covers on the lower case by prying them up with a push pin.
On the inside of the battery compartment, use the tip of a spudger to detach the metal latch securing the volume control switch in place.
Één andere persoon heeft deze handleiding voltooid.
