Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use a push pin to remove the four plastic screw covers on the front bezel.
Remove four Phillips screws securing the front bezel to the rear bezel.
Using two hands, gently slide the rear bezel upwards.
Insert a spudger into the gap between the front and rear bezel
Rotate the spudger away from the DSi XL, prying the two bezels apart.
In the same manner as described above, continue prying along the top edge of the front and rear bezels.
Use the flat end of a spudger to pry the rear camera off the rear bezel.
Remove the rear bezel.
Using the flat end of a spudger, pry the Wi-Fi antenna out of its housing from within the front bezel and move it aside.
Using the flat end of a spudger, pry the left speaker out of its socket on the front bezel.
De-route the speaker cable along the top edge of the screen.
In the same manner as described above, remove the right speaker from its socket on the front bezel.
Place both speakers on the back of the upper LCD.
Carefully push the upper display assembly through its housing in the front bezel.
Rotate the upper display assembly out of the front bezel.
Insert the flat end of a spudger underneath the adhesive strip that secures the front screen to the upper LCD.
Slide the spudger along the bottom side of the upper LCD, freeing the adhesive along that edge.
In the same manner as previously described, detach the adhesive along the left edge of the upper LCD.
In the same manner as previously described, detach the adhesive along the right side of the upper LCD.
Carefully lift the upper screen from the bottom edge.
Pull the upper screen away from the upper LCD.
6 andere personen hebben deze handleiding voltooid.
5 opmerkingen
Yes, you're right. Also there's a gap between steps 7 to 8 because you cannot actually detach the upper screen without disconnect the board cable from the lower screen part.
By the way, I can't quite successfuly open the upper screen part on my dsi xl because it dont seem to give any space between the two covers. Any suggestions?
@Irj7 find the top lcd replacement guide here:
