Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Is your stylus stuck? We're here to help.
Wat je nodig hebt
Remove the two Phillips screws securing the battery cover to the back of the handheld console.
Lift the battery cover off the back of the DSi XL.
Remove the four rubber screw covers on the lower case by prying them up with a push pin.
Remove the two gold 4.0 mm Phillips screws securing the right shoulder button assembly to the back case.
Lift the right shoulder button assembly from the back case.
The components of the right shoulder button assembly:
Right shoulder button
Shoulder button spring
Retaining pin
Right shoulder button holding panel
4 andere personen hebben deze handleiding voltooid.
