Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Replace your DSi XL's speakers so you can hear Mario yell "Mamma mia" as clear as ever.
Wat je nodig hebt
Remove the two Phillips screws securing the battery cover to the back of the handheld console.
Lift the battery cover off the back of the DSi XL.
Use a push pin to remove the four plastic screw covers on the front bezel.
Use a spudger to lift the antenna from the front bezel to make room for lifting the speaker cables up.
3 andere personen hebben deze handleiding voltooid.
3 opmerkingen
In my case, it turned out there was nothing wrong with my speaker… one of the wires that feeds around the screen was bad.
is there anyway of adding two more speaker?
