Inleiding
Use this guide to replace a faulty microphone in your DSi XL.
Wat je nodig hebt
Remove the two Phillips screws securing the battery cover to the back of the handheld console.
Lift the battery cover off the back of the DSi XL.
Remove the four rubber screw covers on the lower case by prying them up with a push pin.
With the console still upside-down, open the DSi XL slightly.
Push the lower display away from the upper case.
Remove the lower display from the DSi XL.
Turn the DSi XL over and open the display.
Use a pushpin to remove the four plastic screw covers on the front bezel.
Remove the Phillips screw holding the metal securing bracket in place.
Lift the metal bracket off the camera.
