Ga door naar hoofdinhoud
Nintendo DSi XL Lower Case Replacement
Wat je nodig hebt
  1. Nintendo DSi XL Lower Case Replacement, Battery: stap 1, afbeelding 1 van 2 Nintendo DSi XL Lower Case Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Lower Case Replacement: stap 2, afbeelding 1 van 1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Lower Case Replacement, Lower Case: stap 3, afbeelding 1 van 3 Nintendo DSi XL Lower Case Replacement, Lower Case: stap 3, afbeelding 2 van 3 Nintendo DSi XL Lower Case Replacement, Lower Case: stap 3, afbeelding 3 van 3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Lower Case Replacement: stap 4, afbeelding 1 van 1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Lower Case Replacement: stap 5, afbeelding 1 van 3 Nintendo DSi XL Lower Case Replacement: stap 5, afbeelding 2 van 3 Nintendo DSi XL Lower Case Replacement: stap 5, afbeelding 3 van 3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Lower Case Replacement: stap 6, afbeelding 1 van 2 Nintendo DSi XL Lower Case Replacement: stap 6, afbeelding 2 van 2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Lower Case Replacement: stap 7, afbeelding 1 van 2 Nintendo DSi XL Lower Case Replacement: stap 7, afbeelding 2 van 2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
Conclusie
6 andere personen hebben deze handleiding voltooid.
David Hodson
150.882 Reputatie
127 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 92
Altijd: 8,778
