Inleiding
Replace a scuffed or scratched front bezel to get your DSi XL looking brand new.
Wat je nodig hebt
Remove the two Phillips screws securing the battery cover to the back of the handheld console.
Lift the battery cover off the back of the DSi XL.
Remove the four rubber screw covers on the lower case by prying them up with a push pin.
With the console still upside-down, open the DSi XL slightly.
Push the lower display away from the upper case.
Remove the lower display from the DSi XL.
Turn the DSi XL over and open the display.
Use a pushpin to remove the four plastic screw covers on the front bezel.
Remove the Phillips screw holding the metal securing bracket in place.
Lift the metal bracket off the camera.
Using a pair of tweezers, pull the microphone out of its housing in the front bezel.
De-route the microphone cable, and pull it through the right hinge.
Using the flat end of a spudger, pry the left speaker out of its socket on the front bezel.
De-route the speaker cable along the top edge of the screen.
In the same manner described above, remove the right speaker from its socket on the front bezel.
Place both speakers on the back of the upper LCD.
Grasp the camera and upper LCD ribbon cables between your thumb and forefinger, pulling them out of the upper case slightly, slide them down through the slit in the upper case.
Rotate the front bezel assembly clockwise so that the ends of the camera and LCD cables slide sideways through the slit in the front bezel.
Één andere persoon heeft deze handleiding voltooid.
