Inleiding
Use this guide to replace your DSi's single Wi-Fi antenna.
Wat je nodig hebt
Unscrew the two Phillips screws securing the battery cover to the lower case.
Grasp the battery cover and lift it out of the lower case.
Using a spudger tool (or your fingernail), lift up the battery from the top.
Grasp the battery and remove it from the DSi.
Two screws are hidden underneath two rubber feet highlighted in red.
Use the tip of a spudger to pry the rubber feet out of the lower case.
Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
Pull the Wi-Fi board away from the motherboard by its edge closest to the headphone jack.
Use the tip of a spudger to pry the power board connector out of its socket on the motherboard.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following three ZIF sockets:
Lower touchscreen cable
Lower LCD cable
Power board cable
After flipping up the locking tabs on all three sockets, use your fingers or a pair of tweezers to gently pull the cables straight out of their sockets.
Use the tip of a spudger to pry the metal backing of the lower LCD up from the DSi's framework.
Lift the lower LCD assembly out of the DSi.
Use a pushpin to remove the four plastic screw covers (highlighted in red) on the front bezel.
