Stap 1 Battery
Voorzichtig: stappen 1-2 komen van een handleiding die in bewerking is.
Loosen the two screws on the battery panel. Then lift the panel up to remove it.
Two screws are hidden underneath two rubber feet highlighted in red.
Use the tip of a spudger to pry the rubber feet out of the lower case.
Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
Stap 7 Disconnecting Nintendo DSi Battery Board
Voorzichtig: stappen 7-8 komen van een handleiding die in bewerking is.
Flip up the black latch and disconnect the D-Pad/Power Button ribbon cable.
The connector is two pieces -- a white "male" piece (connected to the wires), and a beige "female" part (soldered to the main board).
There is a small "notch" in the female part, to give you a place to insert a small flat-head screwdriver. Put the corner of your screwdriver in there, and twist it gently to push the white part up (away from the main board). Do not try to pull it to the right (towards the battery board).
Stap 9 Motherboard
Voorzichtig: stappen 9-10 komen van een handleiding die in bewerking is.
Remove 4 Phillips screws from the board.
Lift the main board from the bottom end and flip it over to reveal the last connector.
Stap 11 Disassembling Nintendo DSi Bottom case
Voorzichtig: stappen 11-13 komen van een handleiding die in bewerking is.
A/B/X/Y button assembly
Select/Start button assembly
D-pad
Power button
Stap 14 Top LCD Screen
Voorzichtig: stappen 14-23 komen van een handleiding die in bewerking is.
Using a spudger, or similar tool, pry out the 4 square screw covers.
On the bottom cover, use a screwdriver to remove the 3 Phillips screws holding the battery compartment.
Removing the 2 lower screws also removes the "L" trigger.
Één opmerking
Pictures are too dark to properly see where the structures mentioned in the text are, but worse than this, Steps 21 and 22 do not properly explain the “twist” method that you need to use with extreme caution! This is the Achille’s heel of dismantling the device and if you’re gonna make a mistake, let this not be the one…
